Hello to everyone here!
I have a question relating to Masso relay or any other solution that will work.
I have used the Masso relay to control my coolant flood pump. Simple on-off, controlled by Masso thru Masso relay. The pump is 120V and I use Ground to activate it thru the Masso relay.
I now want to control the on-off of VFD thru relay, whether Masso or another vendor.
My problem is, My input voltage is 240V single phase. If I use the ground to try to control on-off it doesn't work with 240 single phase. Since the machine is grounded to common ground, taking the VFD ground out of connection doesn't work, since the ground is established in many other places.
My thought initially is, Use 2 relay switches on the Masso relay, each carrying a single line of 12oV, so the 2 relays would be activating 240V in unison, and activate both relays with the same Masso control switch?
In mind this should work, but not sure if the Masso switch is compatible, although, from normal on-off usage of the switch, this should be OK.
any input would be appreciated before I fry my Masso
