grievousangel
Member
SUCCESS Finally!
I ended up using a 4 Ch Sensor (2 or 3 wire) to TTL Out Module that fed a 4 Ch 24VDC Relay Module (TTL Input). That resolved all of my problems related to the (3) external LEDs, i.e., A) 3D Probe 'Touch-Off' Pnk LED; B) Tool Setter 'Touch-Off' Blu LED; C) Tool Setter 'Over-Travel' Blinking Red LED. The relay hard contacts only controlled the external LEDs, thus isolating the external LEDs from the 3D Probe & Tool Setter electronics! All is Happy! The 3D Probe uses an Aviation-like GX12-4 connector, USB to GX12-4 (F) that plugs into the Interface Box near the 'Park' location. The Tool Setter is mounted at 'Park' directly under the tool tip for length assessment. It all ends being a clean installation with no wires or cables hanging around or tossed over there! Another plus is that the LEDs are close at-hand and easily viewed., as the device internal LEDs can be hard to see without moving or leaning over into the work area.
I'll post the schematic and drawing soon.
Later, Billy
Touch Plate / PGFun 3D Probe & Tool Setter Interface Box Project:
The Interface Box is located at the FaceSide Park (MCS) location (opposite FaceSide Home (MCS). The top panel has (3) LED's and (1) Aviator GX12-4 male panel-mount connector.
Touch Plate & PGFun 3D Probe
The GX12-4 panel-mount is used by both Touch Plate cable (GX12-4) and the PGFun 3D Probe USB cable (GX12-4). The duel-purpose Panel LED (Pink) indicates: A) Tool Tip & Plate 'Contact' when the Touch Plate cable is plugged-in to the panel GX12-4; OR B) 3D Probe 'Triggered' when the 3D Probe USB cable w/ GX12-4 connector is plugged-in to the same panel GX12-4. When PGFun 3D probe is plugged-in, the panel LED (Pink) follows the 3D Probe internal LED when 'Triggered'.
Touch-Plate works as expected.
Tool Setter
The Tool Setter is wired directly (GX12-4 interface NOT USED) to the Interface Box via the included flex-metallic conduit (6-wires). The panel-mounted Tool Setter LEDs: A) Sm. Red LED indicated Over-Travel (O-T); Below O-T Red LED B) Blue LED indicates Tool Length OK.
Tool Setter works as expected.
The main issue relates to the PGFun 3D Probe panel-mounted LED (Pink). The internal LEDs work as expected, however the external panel-mounted Pink LED does not 'turn-off' regardless of Normal/Triggered state, i.e., voltage developed is not low enough (> 3VDC) to read 0 binary state. The 3D Probe has an internal R10K between +24VDC and Signal Out. After plugging in the 3D Probe cable, the Pink LED never turns off, but does dim.
Any suggestions on determining the R value to develop < ~2.5VDC when in Normal state. Some research states ... No Rpu required (since it has internal R10k) while others recommend R2K7 for 12V and R5k6 for 24V with an internal R10K.
Anyone know the circuit differences between PGFun and the DEWtronics?
I will attach drawings ASAP.
Later,
Billy
Later, Billy
Tool Setter
Later,
Billy
