@bo
I went to bed after I replied to your initial request. I see you have since edited it.
Googled Touch Trigger Probe TP-100 and found that it is a special NC switch so wire it as per the documentation for touch plate, with an extra wire for ground/negative connection.
Tip of the audio plug to MASSO input, with 5.6k resistor to positive supply. Sleeve of the audio plug to negative supply. Set input in F1 to low when not activated.
PS I'm based in Perth Western Australia and I left Nederlands 67 years ago.
