I am looking to get the masso 4 axis touch to use on my custom 4 axis cnc mill/router
I'm wanting nema 34 closed loop steppers but will use what's recommended if different
need a recommendation for spindle size and rpm
the mill will be 38"x 12"x 18" work area the table with the rotary axis will be around 125lbs dead weight but riding on linear carriage bearings with ball screws
the intent will be to cut wood aluminum and some steel
goal will be high feeds and speeds
thank you for your help and recommendations
