planoguyjc
planoguyjc
Hello, I'm interested in the G3 Controller for my build, however I have a few questions. The application I intend to use it for is a rotary plasma tube cutter.
My plan is to use X-axis to drive the tube, Y- Axis to move torch left and right, Z- Axis Torch up/down, A-axis for Rotary (turn 24' tube), I'll also need another axis (B?) to turn the chuck on the opposite side but I'll need to slave it. I know from the videos it says you can't slave A and B, what would be the solution there? I also saw where you can hardware wire the two motors on the same axis, the material i'm turning would always rotate in sync with the other axis. I would only need to home one of those axis's so is that the best way or should I software set up and change around the axis's in the program? Would I need a 4 axis or 5 axis controller?
This controller seems like it would be a good fit for our application, is the User Interface something that could be changed slightly? Can you rename the icons or delete/add from showing up? I see you can put our company logo on it as well. If this isn't an option to do on the users end, can it be done by Masso for a fee? Any advice would be greatly appreciated! I'm also including a picture of a similar system for reference (not my design)
Thank you in advance!
JC
JC
