4-Axis Wiring G540 Help
dijelements
dijelements
I finally got around to working on my controller using the Masso and Gecko G540. I thought things were all good till I noticed that X,Y,Z Axis is going in one direction. The A-Axis is functioning correctly, I am able to move from left to right. Am I missing something on the diagram or do I need to connect the negative thats noted in the illustration. Note I am not an expert on the electrical piece so please advise. Thanks.
The drawing for the G540 is correct. please do not connect the output pins you have indicated.
The most likely senario is that you have a wiring issue and I can see from the phot you sent that you have indeed wired it wrong.
You have the X Y & Z direction connected S- instead of the D+. That should sort out you problem.
