Hi team,
Does anyone know whether the USB on a masso G3 is 'alive' all the time? I need 5v supply for a signal to my Gecko G203v 'disable' pins and i don't want to install a separate supply for this tiny job. I have thought of using a dropper resistor (nope), a Zener diode arrangement (bit crude) and a buck converter (adequate) which are all at my disposal however the 5v available from one of the USB ports on the masso appeals to me more (K.I.S.S). The current draw will be negligible as it's just a logic '1" i need which will be supplied to the drives via a contact on a safety relay. I'm not up to a stage where i want to power the Masso as my panel is still on the bench and a bit chaotic.
