Add G76 threading
ecs
ECS
Quote from Westyone on August 22, 2019, 2:20 pm
Oh yes! but got to get that backslash working first.
Make space. Bin the wizards! Use CAM.
@westyone - I think the mill controllers software might be running out but not the lathe. We are missing half the stuff compared to the mill controller. You need to request the alpha software to get the backlash. Check with masso.
ecs
ECS
I had a look at the g95 as I didn't know exactly what it did. I'm sure it would be useful but we should definitely just work on one at a time (we don't want to overload masso). The g76 has everything for spring passes, last cut depth, tapered threads and 45 degree pull outs all rolled into one.
We just need more people to say they want it.
@nemo1966
mattjoy
mattjoy
Absolutely essential to have all these features in threading @ecs.
I just looked at the threading cycle on offer , how do you set depth of cut?
concept-fsd
Concept FSD
I'm desapointed , to receive my masso G3 for my lathe in the ultime goal to do thread and them discover than G95 is not supported ... how am I supose to make thread ? enter the pith by my rpm don't sound the best thing to do in the pitch zone in wizard
nemo1966
Nemo1966
Quote from ECS on August 27, 2019, 11:27 am
I had a look at the g95 as I didn't know exactly what it did. I'm sure it would be useful but we should definitely just work on one at a time (we don't want to overload masso). The g76 has everything for spring passes, last cut depth, tapered threads and 45 degree pull outs all rolled into one.​
@nemo1966
G76 should be a minimum, but the G76 relied on G95 ????
I have been looking at buying 3 or 4 Massos to replaced current controllers, but keep hitting stumbling blocks like G76
pvt
PVT
Quote from evermech on August 22, 2019, 2:27 pm
I say yes to G76 and G95 both are mandatory G codes
Yes. I bot the Masso controller for my lathe. I need also G76 and G95 G codes. Thanks in advance.
P. Viktor
cameron
Cameron
Will probably be buying a masso this year and this would defiantly be a factor for me. It is defiantly needed.
nemo1966
Nemo1966
Just about to refit 3 lathes and 2 millers, sadly I have had to go in a different direction to Masso due to lack of these basic features.
