Admin area key switch
Great idea!!
Sometimes I forget to sign in on the F1 screen and then want to make an adjustment and I can't without rebooting the MASSO. If there is a way to bring the F1 admin login screen back after a failed login, I haven't found it.
tekmobile
tekmobile
What about the original subject lol
What I'm hoping for is to have the option to assign an input to a physical key switch that will allow write access to the admin area
So you can view the admin area as a user but not change any values but turn a key to allow data edit
Quote from MASSO Support on May 24, 2019, 9:05 pm
you can always press CTRL+L and the password window will be displayed
In the keyboard shortcut page, CTRL + L is listed as Lock system and as such doesn't imply that you use the combination to bring up the password dialog for unlocking.
Changing the wording to LOCK / UNLOCK SYSTEM would be helpful and adding to the password page / video that CTRL + L will lock / unlock the system.
PS A key controlled input to lock / unlock would be better.
