Hey guys,
Figured I might get a good advice from someone on this forum. I'm try to get a good 3d surface finish on some test parts I made. Material is 3D printed PETG which should be similar to machining ABS. I'm using a 2 flute 1/4 ball mill amorphous diamond coated from Harvey. Stepover of the pattern is 0.5mm but i feel i could go a bit higher and not have a scalloping effect. I don't have air cooling at the moment (compressor is defective) but i might try this. It feels like it's re-cutting chips. See pictures ... any advices?
