Incorrect spindle configuration can lead to damage of the Spindle, the VFD or both.
This diagram is based on the default configuration shown in the VFD documentation.
Please be aware that changes made to configuration and link on the main board may make this drawing incorrect.
Spindle VFD examples
Manufactures Website
AMB Milling Motor 1400 FME-W DI 230V (for ER16 precision collets)
Powerful universal motor with pneumatic tool change system and digital control option - extremely robust and optimized for milling work of any kind -…
Speed Control
This spindle has a non standard 1-9v speed control signal instead of the 0-10v used by other spindles.
This will give a non linear speed when used with MASSO
Fellow forum member ZombieEngineer has devised this simple divider circuit to bring the speed control into line with MASSO speed control.
It can be made with 3 readily available electronic components. The connection diagram above does not include this circuit. Add as needed.
Masso output on the left, AMB input on the right. If the configured maximum spindle speed is 22,000 then the AMB spindle should match within 0.5%. The above circuit is effectively a voltage divider with the diode providing a voltage bias [ Y = 0.95 x (X - 0.6) ]
