tayloredtech
TayloredTech
@masso-support Hey Jatinder, hope you and the fam are safe and well right now mate.
I'm doing a rebuild-upgrade to the Multicam machine at the moment to make it a 5 Axis 2800mm x 1400mm x 450mm chip monster and adding an interface to control the ATC and axis movements from a 3rd party interface.
Much appreciate your answers,
Mitch
- I noticed there are inputs for moving XYZ but not A or B, is there a way to add these?
- Is there a possibility for inputs to home each axis individually from an input or should I just use the inputs for pre-saved G-code and insert them there?
- Tool change inputs only go up to tool 8, I will have 10 tools on my ATC so is it possible to add more? or again should I used pre-saved G-code inputs( though there are only 6 slots available and I will need 5 for the above homing of each axis)
- Is there a reason we can only job one axis at a time? currently you have to wait until the machine has completely stopped before it can change direction? The original controller could move the machine around in all directions.
Mitch
