The impact of the high air blast pressure is good information to know, and a great bit of troubleshooting on your part. I have recommended the spindle we are using on other forums and I frequent, and will be sure to remember this should anyone there encounter the same issue.Hi Dylan
All looks good there are many different ways to do the pneumatics and all of them can work
My one tip is to make sure your tool holders have some flex in them they need a bit of give
and just be careful with your dust / Air blast pressure as if it a little to high you get a trapped air cushion that pushes the Iso25 tool holder 9or what ever you are using ) down up to 5mm bending the printed rack tool holders or if they are not flexible they will snap I thought I had a problem with the safe Z distance setting then I though it was low clamping air pressure but in the end it was air blast / dust pressure that was to high
anyway keep in touch I would be keen to follow your progress
one last thought I would add at least one more filter / Water traps to the system, compressors that run a lot, pull quite a bit of water out of the air and you need to be able to control that efficiently
Cheers Bill
The warning of accumulated moisture is also noteworthy. I am always surprised at how much I drain out of my tank at the end of the day and my 3D carves. One thing I did was modify one of my filters by removing the micron cartridge, and replacing that volume with blue silica gel desiccant beads. I have my pneumatics in an enclosure, and every few days just have a look inside to see the colour of the beads. It just adds a third line of defense against moisture, but also helps determine the state of things in my line.
