ATC Spindle Motor
madscientist
madscientist
Hi Roie,
there are a bunch of videos on youtube where people have set up ,magazines or carousels for an auto tool change and then the machine touches off on a 'touch setting plate' before continuing on with the next part of the operation.
before changing spindles:
what is your current set up? can it be modified to accept a draw bar?
be careful, if you introduce a water cooled spindle as in your link, thats a whole new system to install
how many different tools do you normally call in a program?
rroie
rroie
I have a router CNC not a metal mill. See attached. I have water cooling already. Machining a two sided, lidded bowl with carvings and legs I can change the bit 6 times. Not 6 different bits.
Thank You
Roie
