Shellby429
Member
With so much call for it, I’m finding it difficult to understand why there is no action on this. The early post comments were it will be a simple change if people were interested. Confused
Not hard at all as the linear tool changer has done this since Day 1How difficult can it be to program in such a way that, when calling for a tool number, Masso checks which slot (1 to 8 for us) is assigned to that tool and then pick it.
Thanks Peter. I was not aware of this update.@Shellby429
But it has been included in the current V5.100 beta version for users to test.
So far we have had no negative feedback on the manual tool change added into the linear tool changer.
It will be a while before the Beta is stable enough for daily use and there are a lot more features to be added that others have requested but the request has been heard and implemented for initial user testing.
Is this not the feature that you were requesting?
A Beta version means it is a test version and will most likely contain bugs.Where do I get more information about this? I’m not overly familiar with your reference of this not being stable for daily use.
The Beta version was released on the 20th of October and all users were emailed.I assume version 5.100 beta version is available to download? Can you let me know any risk associated with this download and what I should be aware of here?
I cannot answer this for you. Trying it now or waiting for the next Beta release or even testing it at all is entirely up to you and is a decision that only you can make.Sorry your reference of not being stable is confusing me and unsure if I should download and test or not.
Absolutely fantastic Peter. Thank you for this little detail I missed. I'm going to play with it right away.To free a tool slot look down the list of tools in the F4 screen and see the tool allocated to the required slot.
Open the tool by double clicking on it and set the "Tool in Slot" to "Not Loaded"
Press Save.
You bet I'm going to try this at some stage, thanks.I gave the 4-5 end mills used for this job, different slot numbers but these slots all share the same X/Y tool change position.
