B axis issue
waynep
waynep
I'm running a four axis setup using chinese nema34 motors and drivers. I used the leadshire diragram for set up and all is well except for the B axis. It only runs in one direction. If I switch it to the z or x plugs it runs both ways. Where am I going wrong in the wiring?
Driver MASSO
(1) pul+ S+
(2) pul- D+
(3) dir+ S-
(4) dir- D+
ian-mellin
Ian Mellin
Hope this helps.
I have the first eddition of the Masso and in order to get the axis to go both the same direction, you use the slave option.
The Y axis slaves to the B axis
The X axis slaves to the A axis.
If you have the same mema 34's as I do I tracked down the documentation I have attached.
Kind regards
Ian
waynep
waynep
I'm not seeing any attachment. I am using the B as the slave for Y, it will run but only in one direction.
@waynep
The connection you show in your post is incorrect and I am assuming here that you are using the G3 as you show the B axis as having 4 connection points on Masso.
It should be.
PUL+ ------ S+
PUL- ------ S-
DIR+ ------ D+
DIR- ------ D-
