BD600 VFD hook up to MASSO
solargrown
Solargrown
I need some help hooking up a Folinn BD600 VFD to MASSO.
Hopefully all the required details are in the attached/uploaded PDF and somebody can edit it to show correct connections.
  1. Firstly you need to wire Pin: 4 from MASSO to S1.
  2. Connect Pin: 5 from MASSO to DCM.
  3. MASSO Pin:1 to AI1
  4. -ve of MASSO power supply to ACM
  5. If the motor does not turn then try swapping above Pin 4 and Pin 5
solargrown
Solargrown
THANK YOU
Glad I asked before wiring it up.
That worked, had to swap Pins 4 & 5.
I'm coming across from Mach3, which allows you to set a dwell time for the spindle to reach requested speed before movement.
Is the only way to achieve this with MASSO to make sure gcode has a G04 P** after M03?
thats great.
For the spindle delay, we have added the option already to the new software release that is to be released in the next few days.
Connection diagram for BD600 VFD
Please be aware that this VFD has links that can change inputs from PNP to NPN.
Inputs for forward and reverse are assigned in the VFD configuration
This drawing is based on the Default settings shown in the manual.
It is advisable to follow the installation process shown in the video on this page to ensure you have a correctly configured VFD before comencing with connection.
  • BD600_Series_Inverter_User_Manual.pdf
