agoodevans
agoodevans
I've tried Powering Off/On,
Work co-ordinates show X values as negative going up away from job. Machine values are correct, jog movement is correct. How can I flip the work X values back to positive values? From reading on this forum, it appears to be a G54 issue.
I have tried adding another G code to try and clear it in the MDI. Prolight Lathe 2 axis. G54 is black at bottom of screen. Is that active on not? Running Core 1.26, Ver 3.40
Any advise would be appreciated.
