Can't resume gcode
sourabh
Sourabh
Hello everyone
Whenever i try to resume the gcode after power off.... The masso gets stuck. I can't do anything after i press cycle start.... And the machine won't respond. I have to restart masso and have to run the program from zero.
Hi Sourabh
What version software are you running. There is an issue with an earlier version that I know of but if you are running V3.40 or later then you will be ok.
Have a look at this video which demonstrates how to use the Jump to line feature. It demonstrates how to do it after the power has been turned off.
