Can't use very low adjustment speed for THC
jolbas
Jolbas
I found there is a limitation for how slow the height adjustment speed can be. After some testing the limit seems to be at around 1kHz pulse rate. That is slowest. I can increase the amount of microsteps on the stepper driver to get a lower adjustment speed but then I sacrifice maximum speed on Z. I like to keep the adjustment speed at around 10% of feed and now it's not possible for thick material low speed cutting.
Bj rn
jcoldon
jcoldon
masso has a long way to go to fix there thc and add controlls to the screen this is why oem given up on the controller
jolbas
Jolbas
@jcoldon.
Hm. I don t find that helpful at all.
My THC actually works very well now. This is A small problem and I was looking for someone who maybe have similar issue and then maybe even a workaround.
jolbas
Jolbas
Yes.
M667 F200 works as expected but M667 F100, M667 F50 or M667 F20 don't. All last three results in the same adjustment speed that is around 140 mm/min.
what's your Z axis max feedrate and acceleration settings in F1 screen, will do some tests with the same settings.
thanks @jolbas and we checked and yes it does not work on a very low feedrate. Have fixed the bug, can you please let us know your controller serial number and will email you the test software.
ae_mike
AE_Mike
May I get that patch as well? my controller is 5A-3110 with v3.40.12pre. I'm just in the bring process now and plan to have the THC operational by the end of next week.
