Im new here, it looks like interesting board but, i have loads of questions.
Thank You all, any other insights will be appreciated.
- Is it able to read absolute linear scales and rotary encoders and position based on them? As just relying on ball screw positions even C3 is not going to cut it for me.
- If all encoders are in place is it able to position spindle to exact angles and do orbital milling (Even if i have to generate the path on my CAM)? That requires 5 axis simultaneous positioning, any chance to upgrade for additional axis or is it able to control spindle angle positioning from the spindle I/O + encoder information?
- Is it able to take in parameters like where the center of table is, all the distances and parameter required for 5 axis milling, so it can then translate to different planes etc?
- Can custom cycles be created, i mean real parametric cycles not just subs.
