Hi All,
Ive been working on my Electrical Panel Build for my DIY Router / Spindle Table build, utilizing the Masso G3 Touch Wiring Module. Ive searched forum after forum, and found answers to most of my questions, but im still iffy regarding the use of the Pull-Up Resistors. I was hoping someone smarter than myself could take a quick peek at my "Schematic" and see if I made any errors on the Masso Input side of things. I found Forum Threads regarding Stepper Alarms, Push Buttons, Homing Sensors, pretty much everything, and from what I gathered, I need Pullup Resistors for everything. For the most part, Ill use the Dip Switches on the Touch Module, but a few items (like the Stepper Alarms) seem to require larger Resistors. I found the thread regarding Bussed Resistors, bought a couple to try out and was able whip something together. This is purely a DIY build for me, so Im trying to quadruple check myself before I fry something. If anyone is willing to take a look, Id really appreciate it. Though my schematic shows an image of a G3 Touch, its all actually wired to the Touch Wiring Module as im mounting it in my enclosure. Ill list the components w/ Links I'm using or will be using if it helps.
Tool in Place & Drawbar Status Sensors = (PNP) Built in Jainken Spindle (JGL-80/2.2) https://www.jian-ken.com/automatic-...l-80-1-5kw-2-2kw-2-5kw-24000rpm-40000rpm.html
Touch Plate = Basic Aluminum Square Style similar to link, but Ill make my own https://www.amazon.com/Z-axis-Setti...&sprefix=cnc+touchplate,industrial,130&sr=1-2
TS Touch Off & Over Travel = https://www.amazon.com/dp/B09VB987DV?ref=ppx_yo2ov_dt_b_fed_asin_title
Go Home, Go Park, Extra1, & Tool Release = https://www.amazon.com/dp/B08SKJ6V7Z?ref=ppx_yo2ov_dt_b_fed_asin_title (will 3D print mounts for these similar to DashMade's EZ Buttons)
Dust Hood1 = Parker Air Cylinder NCDMB075-0200T-M9BS (M9B is the Sensor, Solid State, Gen Purpose, 2-wire) https://www.smcpneumatics.com/Part-Builder-Products_ep_2414-1.html?NCDMB075-0200T
Y Home, Y Limit, & B Home = (NPN) https://www.amazon.com/dp/B00TX5XDE8?ref_=ppx_hzsearch_conn_dt_b_fed_asin_title_1
X & Z Home = (NPN) Coolant Flow Sensor =
Stepper Drivers (ALM) = (CL86T) https://www.omc-stepperonline.com/c...24-110vdc-for-nema-34-stepper-motor-cl86t-v41
Air Pressure Switch = https://www.amazon.com/dp/B07RLJK6WT?ref_=ppx_hzsearch_conn_dt_b_fed_asin_title_3
Am I going overboard putting Pull-Up Resistors on everything, and did I even do it right? I used this project as a way to force myself to better understand electrical, but this whole Resistor thing has me second guessing myself.
Thanks for any help / criticism, I know my "schematic" isn't really proper or spec, but the layout makes sense to me.
Im happy to provide any additional information I can if it helps.
