Chip Auger
homebrew_cnc
homebrew_cnc
My machine has a chip auger, but it's currently on a switch. The HAAS post processor I'm using allows for it but the Masso does not. Being inexperienced in coding, I cannot imagine it would be much different than the Coolant/Mist/Cycle start commands via relay/output.
Yes you can use one of the relay outputs for that, you can use digital output mcode to switch on/off the relay. M62 P1 will switch on the Output:1 and M63 P1 will switch off this output.
