i type TIME:12:12 and press enter on mdi comand,, nothing happen,, clock on the system wont change..
M madi madi Sep 7, 2018 #1 i type TIME:12:12 and press enter on mdi comand,, nothing happen,, clock on the system wont change..
masso-support MASSO Support MASSO Team Sep 7, 2018 #2 please see this link: https://www.masso.com.au/docs/masso...tion/keyboard-and-key-shortcuts/setting-time/ The command is Time:12:12 and TIME:12:12 will not work. Also if you are using MASSO Link software via wifi then the time will automatically be synced with the PC time.
testyourdesign testyourdesign Sep 8, 2018 #3 @masso-support I didn't know you included time syncing feature with link software but it makes allot of sense. Thanks for the information.
M madi madi Sep 8, 2018 #4 thanks,, so the alphabet is also make a different , not in the regular mdi command . note that, module for the wifi i not purchase yet,,
masso-support MASSO Support MASSO Team Sep 9, 2018 #5 yes it does make a difference and has to be exact because its a special command and we have to keep it separate to any other MDI commands.
