CNC Lathe retrofit with Dual Handwheels / MPG
knastenrad
knastenrad
Hi . I have a Pinacho Taurus 260 lathe that has a bad Fagor controller.
Looking at the Masso G3 as a alternative for retrofit
The machine has a dual handwheel setup that is useful for some manual work
I see there is a MPG port on the controller but it can only be used 1 axis at a time , by selecting the axis/rotary switch
But is there a possibility to use som of the digital inputs to make the controller Jog both axis X+Z , from the handwheel signals?
i asume i need some sort of a signal conversion from differential to "single output"
an alternative could be a version of these https://www.aliexpress.com/item/400...earchweb0_0,searchweb201602_,searchweb201603_
