CNC on Masso
nem
NEM
I m totally new to CNC machining. But I was thinking of buying a CNC Router to machine aluminium and composites.
I ve been looking for a router with x,y,z with a 4th axis rotary head, for machining at angles.
I was checking out this website, when I saw a video of a CNC Router, in the Complex Machining section. It s shows a Hertz high speed spindle head machining a length
of plastic or composite. The head moves through the x,y,z axis as well as pivots through a 4th axis to machine up to right angles. The sort of thing I m thinking of.
Can anyone please tell me the name of the CNC Router maker?
Hi NEM and welcome.
Could you be a little more specific. Complex Machining section of what?
Do you have a link to the video you are referring too.
nem
NEM
Hi Peter,
Thanks for your welcome.
It is the video on this websites home. Showing a Hertz spindle machining through a 4th axis 0 to 90 degrees.
Thanks NEM.
Hi NEM
Found the one you are talking about. The machine in question is a custom built 5 axis machine.
To get one like that you would need to design and build it yourself.
