bensplasmaau
BensPlasmaAu
Good morning all,
I have a home built Plasma table, it currently runs a UCCNC and Neuron THC. So far it has worked, but the documentation on the Neuron is not the best. The owner of the company is definitely contactable and helpful, but he is in Ukraine and it s just hard to find a time zone that works with both of us. Also every 2 hours or so, it resets itself and loses conenection over the Ethernet.
The Neuron THC connects directly into the UCNC application and you can change the voltage required via using the tool/cut charts in UCNC. So this is useful. I had run a CandCNC Dragon Ethercut with DTHC IV previously and although it kind of worked, it had many reliability issues regardless of following their instructions to the letter. Also if I had an issue their only suggestions seemed to be to return the unit for rebuild, or I was the cause of the error and was treated like an idiot. I am in Australia, they are in the US.
What was really good about the CandCNC controller was that you could set your required voltage directly from Sheetcam with the post processor and the SheetCAM tool library. No need to select a tool from Mach3.
So I was thinking of doing an upgrade to a MASSO controller and Proma THC in an attempt to get some better support and a more reliable system. Can someone tell me a little bit more about the PROMA THC. Can it be programmed to act like the CandCNC and enable the voltage to be set from the post? I ve read a lot about it, but nothing like this. Perhaps I have missed it along the way.
