CNC4PC supplied spindle encoder?
@westyone this encoder has another problem, it's working voltage is 5v and has differential output signal, so by the time you wire it to MASSO the voltage signal going into the inputs will be only 2.5 volts (the half of the encoder supply) and MASSO needs at least 5v input to work.
The best is you get PNP encoder something that works from 12v to 24v
westyone
Westyone
Hello - I have ordered and received the Masso optical encoder. The "Pulley Sticker" generator on the web site does nothing when clicked?
Thoughts?
