Connecting Machdrives with MASSO
Connect the MASSO axis connector to the drive as below:
  1. MASSO S+ to drive STEP
  2. MASSO D+ to drive DIR
  3. MASSO -ve of the power supply to drive 0v
ned
ned
hey there, love the forum well done, much needed. I have been working on the diagram below, adding to it as i figure it out. This one is complete, I think its correct.
* Its not complete, its missing the 4th encoder wire = ground. will update when complete.
ned
ned
This is where I'm at., at the moment.
I'm powering the masso, the machdrives servo drives, and the encoders all from the same source, which is a device on the gerber power supply, its spits out 5V and 15V.
I have created a shared ground for the 5V encoders/servo drives near to the masso -ve
Images, lots of them, sorry
This diagram can be blown up, its' the finished wiring configuration.
This is the Gerber power supply
This device below puts out +5v and +15v.
I was going to use the 5V for the encoders & machdrives, and the 15V for the masso
here is the terminal block with capacitors across the +5v and -5v signals, with a heavier wire running from the masso -ve to the -5v terminal.
This is my control ground.... I hope I've done this right.
