Connection diagram between the HTG5A1S controller and the Mitsubishi servo amplifiers MR-J3_A series
rojher
Rojher
Hi, Masso.
Very grateful for your willingness to help in configuring the HTG5A1S controller, I apologize if they are very trivial questions.
1. The HTG5A1S controller has many ports of entry and exit, if you formally request your advice (which has a cost in USD), what would be the scope of your work in the wiring diagram? Includes ports:
1.1 OPTO ISOLATED INPUTS 1 UP TO 32
1.2 ENCODER A B Z
1.3 ANALOGUE 1 2 3 4
1.4 SERIAL Rx Tx GND
1.5 D + D- RS485
1.6 E STOP 1 2
1.7 TTL OUTPUTS
1.8 SPINDLE CONTROL
1.9 X AXIS, AND AXIS, Z AXIS, A AXIS and B AXIS
1.10 RELAY OUTPUTS .
2. In the Mitsubishi MR-J3-A user manuals I found the names of the pin abbreviations for the input signals of the CN1 port for the control of the amplifier, my doubt is that PIN corresponds to the input port of the HTG5A1S for the X Y and Z axes (S+ S- D+ D-).
https://www.unisgroup.es/pdf/EN/Mitsubishi-MR-J3-Beginners-Manual.pdf
Tab. 4-2 Signal arrangemant of CN1 in MR-J3-A (Pages 42 and 43).
Pin number 10 PP - Pulse train signal for forward rotation.
Pin number 11 PG - Pulse train signal for reversed rotation.
Pin number 35 NP - Pulse train signal for forward rotation.
Pin number 36 NG - Pulse train signal for reversed rotation.
3. The output pins of the MR-J3-A amplifier are connected to the input pins on the OPTO ISOLATED INPUTS port of the HTG5A1S?
4. I want to connect my fourth axis with port A AXIS, how would the connection be since it only has 3. S + D + G ports?
5. The page of mass does not remember my password, every time I want to publish or ask a question in the forum it tells me that my password is invalid, I must request a new password to the email rojher.laguna@gmail.com
After I give change and the page does not recognize, what will be my problem?
Thank you.
rojher
Rojher
By analogy to what is indicated in the user manual Masso v1.29 - 23 August 2018.
Teknic - ClearParth Wiring. (Page 177)
I have taken Direction (D) for the Forward pulse and Step (S) for the Reverse pulse.
Can someone tell me if it's okay? Thank you
rojher
Rojher
For the A and B axis I have this proposal, will it be fine?
Thank s
tried to find the details about PP or PG in the manual but cant find, what page no. are these explained?
Also found on page 96, you will need this later but you need to set the mode as per the attached image.
rojher
Rojher
Very grateful for your technical support, I learned a little.
1 ) I must program my amplifier in POSITION CONTROL mode to be compatible with Masso.
2 ) The pulse train format I put it in the mode suggested by you (Pulse Train + Sign)
3 ) It must allow the writing to make any modification in the parameters of pulse and signal for the moment of the tests.
I continue learning and I value your orientation a lot, also a Masso user has helped me a lot.
yes that is the right way, because even if your wiring is good and the parameters are not correct still the motor will not run.
