Connection of Chinese Router
rossco
rossco
I am presently upgrading an old Chinese CNC Router;
The Stepper Drives are YASKAWA SGDM-10ADA, URL to Stepper Driver http://www.servo-driver-motor.com/p...GMGH/SGMSH/SGMDH/SGMCS&brandid=4&DownloadID=0
Stepper Motors SGMGH-09ACA61
The original controller is a PMDX-122 rev D, URL to PMDX manual https://www.pmdx.com/Doc/PMDX-122_Manual_112.pdf
The controller has Step and Direction, and Common output
Can you please advise if I need to wire the Common Output to the Stepper Drive and if I do do I connect to the -24V feed.
Appreciate any advice
@rossco - The SGDM-10ADA is not a stepper motor driver but a servo motor driver (servos are more desirable than steppers).
The diagram in section "6.3.2 Position Control Mode" is the relevant wiring arrangement for use with Masso.
Ideal wiring (if you have access to every terminal in CN1):
  • Masso Axis S+ => SGDM-10ADA PULS (CN1, Terminal 7, Yellow-Red, 1 dot)
  • Masso Axis S- => SGDM-10ADA /PULS (CN1, Terminal 8, Yellow-Black, 1 dot)
  • Masso Axis D+ => SGDM-10ADA SIGN (CN1, Terminal 11, Orange-Red, 2 dots)
  • Masso Axis D- => SGDM-10ADA /SIGN (CN1, Terminal 12, Orange-Black, 2 dots)
Alternative wiring:
  • Masso Axis S+ => STEP in previous wiring
  • Masso Axis D+ => DIR in previous wiring
  • Masso GND => COM in previous wiring (50% chance that this is correct, no damage should occur if wrong)
If the "alternative wiring" does not result in any motion then things gets a little complicated (will require a +5V voltage regulator of some kind)
rossco
rossco
Many thanks for the response and advice, my apologies you are correct they are servo motors.
Yes I do have full access to all CN1 terminals, as a matter of fact I need to re-create the wiring, I should be able to give this a try over the next day or so.
rossco
rossco
I am in the process of re-wiring CN1, in doing so I note the existing Servo Drives had at one time been wired to a number of safety switches to prevent over travel, ie Terminal 42 to prohibit forward run, Terminal 43 to limit reverse travel. I am incorporating MASSO homing sensors. My question is should I re-establish these safeties as a back up or does the MASSO homing sensors make them redundant.
Terminal 27 is used as an indicator light
Terminal 31 Alarm
Terminal 30 24Volt Common
Terminal 40 Servo On
Terminal 44 Alarm Reset
Terminal 47 24 Volt +ve supply
Appreciate any advice.
Once this is sorted I need to check the Servo Drive programing.
Many thanks
Rossco
@rossco
Rossco,
When you setup MASSO axes, two of the settings are Maximum, Minimum travel points and MASSO uses these to create soft limits that prevents it from travelling past these measurement points. https://docs.masso.com.au/wiring-and-setup/setup-and-calibration/axis-calibration
Also read the section Axis Configuration and Homing Switches and setting up homing in the Quick Start guides. https://docs.masso.com.au/quick-start-guides/setup-masso-mill
So any limit switches connected to the servo drivers would be redundant.
Certainly connect servo alarms to X, Y, Z, A, B Motor Alarm Input.
rossco
rossco
Arie:
Many thanks for all the support, I was hopeful they would be redundant and an alternate technology for protection when used with controllers without the flexibility of the MASSO.
It will make life a whole less complex.
Cheers Rossco
Homing switches double as hard limit switches once homing has been completed.
Reference: https://docs.masso.com.au/wiring-and-setup/setup-and-calibration/soft-and-hard-limits
All homing inputs on MASSO are automatically used as hard limit input. During the homing of the machine these inputs are used to home each axis and once homing is complete, these inputs are used to trigger a hard limit alarm that stops all motion and spindle. A hard limit alarm is flashed on the screen.
crossfire
Crossfire
Quote from ZombieEngineer on December 17, 2020, 12:15 am
Alternative wiring:
Thanks Zombie, Been reading for hours trying to solve this problem.
Lorin
New member
@rossco - We are doing a conversion like yours using the same sgdm drives. Do you have any input for proper wiring connections and drive parameters and settings?
