controller placement
rroie
rroie
Can you use extensions for the mouse, keyboard, monitor,pendant, etc. The masso is going in a box that is on the other end of a 6 ft bed. I do not understand slaving. I have uccnc and mach3 and the a axis is slaved to the y axis. It is not the same for masso?
Thank You
Roie
ya sure you can use a USB extension cable, USB HUB as required, just keep the wiring away from high noise wiring especially spindle motor wiring etc. You can even use a wireless USB keyboard/mouse.
On MASSO you will have to slave the B axis to Y, A can only be slaved to X axis.
