OK I know what I did wrong.Not so sure about that...Looks more like it's the current date than the version date (unless you just happened to update the version today).
I'll fix it later today.
The tool table may have 105 positions but MASSO can only use 100 of them. Tools 101-104 are multihead spindles and cannot be assigned slot numbers.it should populate all your tools.
Things will be different between beta and main stream versions.Ill test it out tomorrow and see if they can be selected or if they are getting dropped
As I was developing it, the latest version appeared in the current post, but that caused a problem in that I had to edit previous post, so I reverted to uploading it to the original post.where can one download the latest version of your tool from?
For Linuxcnc ext = tblwhat does your utility expect to see as far as file extension etc goes
Program is written in C and uses sqlite libraries to handle the db & vtdb files.is there any plans to make this cross platform, or offer the source so others can
I was a software engineer in a past life, developing in C++ and Java. I still dabble a little bit, so happy to help out if you need? I know that SQLite is available for Linux, and there is a port of VBS supplied by MS. There is even a .NET port, although I believe this is still pretty buggy.Program is written in C and uses sqlite libraries to handle the db & vtdb files.
This is largely the reason I went back to Linux. I used Linux heavily when I had my software company in the early naughties. Then work needs forced me back to Windows, but I never liked Win11 from the get go, and with most apps now available in cloud form, I find MS doesn't have the stranglehold that used to.I would have continued the upgrade path to Win11 if it wasn't for the security hardware restriction.
