Hello,
I'm new to Masso therefore I need some help.
Currently I'm in the process for converting my router from Mach3 to the Masso G3 controller.
The router uses some older type steppers drives (NC-step).
These drives have an option for a sleep mode when the router is in rest.
This option will reduce the current to the steppers to 25%.
I m looking for a way to use this option.
I can enable or disable this feature with a output and command it with M64/M65 in the G-code file at the beginning and the end.
But I think this will not work when I use the MPG after running a G-code file and the drives are in sleep mode.
A another option could be using an auxiliary output that will respond on the E-stop, but the only outputs that react on a E-stop are the tower lights but they blinking and don t give a constant signal.
Anyone an idea how to solve this?
Best regards,
Piet Versleijen
Best regards,
Piet Versleijen
