Good Evening!
I'm having an issue where my programs will not begin when I select cycle start at the beginning of a cut or when a tool change is called. It's been doing this since day one that I got my machine working so on software version 3.42 and 3.43. I'm using the MASSO post processor for Aspire (inches). I'm sure I'm doing something stupid... any help[ will be great.
Full Description: Cycle start does not begin the program. I have to hit single block then cycle start until my spindle turns on. Then I turn single block off and back on. It then moves to the beginning of the program. I select single block and again, cycle through the first few lines, turn single block off, then when I hit Cycle Start the machine runs smoothly.
I have been making separate files for each tool needed because when it calls for the tool change, I will change the tool and hit cycle start or CTRL+S and nothing will happen. If I press single block, it moves to the beginning of the program, which does me no good lol.
Below is some of the code for a program requiring a tool change. First tool runs fine with me completing what iI stated above.
( File created: Sunday December 22 2019 - 08:16 PM)
( for Masso from Vectric VCarve Pro / Aspire 9.5)
(Post Processor version Imperial v1.1)
( Material Size)
( X= 12.000, Y= 12.000 ,Z= 0.500)
(Toolpaths used in this file
(text_tree [Clear 1])
(text_tree)
(outter ring)
(profile and tabs)
(Tools used in this file: )
(6 = End Mill {1/4"})
(0 = V-Bit {90.0 - 9/16"})
(1 = End Mill {3.175 mm})
N160 G00
N170 G20
N180 G17
N190 G90
N200 G80
N210 (End Mill {1/4"})
N220 T6 M06
N230 G00
N240 S12000 M03
N250 (Toolpath:- text_tree [Clear 1])
N260 ()
N270 G94
N280 X0.0000 Y0.0000 F60.0
N290 G00 X6.0861 Y5.5375 Z0.2000
N300 G1 X6.0861 Y5.5375 Z-0.1000 F30.0
N310 G1 X6.0874 Y5.5380 Z-0.1000 F60.0
N320 G1 X6.1437 Y5.5547 Z-0.1000
N330 G2 X6.1289 Y5.6532 I0.5194 J0.1285
N340 G1 X6.1287 Y5.6566 Z-0.1000
N350 G2 X6.1596 Y5.8682 I0.5342 J0.0300
( Material Size)
(text_tree)
(outter ring)
(profile and tabs)
N160 G00
N170 G20
N180 G17
N190 G90
N200 G80
N220 T6 M06
N230 G00
N240 S12000 M03
N260 ()
N270 G94
