Delta MS300
Caution: Before any VFD can be used it must first be configured correctly to work with your spindle.
Incorrect spindle configuration can lead to damage of the Spindle, the VFD or both.
This diagram is based on the default configuration shown in the VFD documentation.
Please be aware that changes made to configuration and link on the main board may make this drawing incorrect.
Please follow the step by step install procedure shown in the VFD install video
The manual for a Delta MS300 can be found here
Whatthefilament
New member
@cncnutz Is there anyway you could help outline how you could wire the MS300 safety feature to the ESTOP Function? Trying to decide if I should wire the VFD power to a contactor or use the internal Estop.
As I read it there is a link between the +24, S1 & S2 so why not put a relay in the +24v line.
Alternatively remove the link and wire it as per the VFD manual using an external 24V power supply.
