Delta VFD M Series Issues
adstaggs
adstaggs
I made all the connection according to Masso Documentation on Delta VFD M Series to spindle, I am able to get the spindle working from the front panel of the Delta. I made changes to the Spindle settings on the Masso F1 screen, but when I go the F2 and click Spindle CW or CCW and nothing happens. I might be missing Programming on the Delta that hands off control to the Masso.
adstaggs
adstaggs
I figured it out, Had to change Pr.00 from 00 to 01 but not sure if I should change Pr.01, also the RPM seems stuck at 4.60 but only show on the keypad and not in masso.
Did you try an mdi command
type in m03 s500 and hit enter, you should get 500 rpm in clockwise direction. Make all is clear before hitting enter key!! If not working you will need to look at some more settings.
