Desperate - G03 Rapids on lathe
edwardproj
Edwardproj
I'm currently setup as I write this, my Masso G3 is the latest version for lathe. I have just created code on fusion 360, did a dry run on my machine to find that the G02 and G03 movements rapid, please help me fix this ASAP. Attached is my code, hopefully it's a G-code that's the issue and not the controller. It is the line at N155 that rapids, even if a place a feed there it still rapids.
O1001
N10 G90 G94 G18
N11 G21
# PROFILE ROUGHING1
N14 T1 M6
N15 G54
# PROFILE FINISHING1
N140 G95
N141 G97 S950
N142 M3
N143 G0 X50. Z5.
N144 G96 D1200 S200
N145 M3
N146 G0 Z2.728
N147 X6.347
N148 G1 X4.771 Z0.89 F1.
N149 X10. Z-5.646 F0.18
N150 Z-17.271
N151 X10.25
N152 Z-44.15
N153 X17.05
N154 Z-74.469
N155 G3 X27.75 Z-85.8 I-9.325 K-11.331
N156 G1 Z-99.95
N157 X31.75 F1.
N158 G0 X50.
N159 Z5.
N160 G97
N163 M5
N164 M30
Hi Edwardproj
I see in your Gcode file you have set your feed rate based on revolution speed
G95 Feed per revolution. The faster the spindle turns the higher the feed rate.
You have also turned on constant surface speed so the closer the cutter gets to the center the faster the spindle speed will be and the faster the feed rate will be.
What is the spindle speed when doing the G2 & G3 commands and feed rate are you getting at those times.
You should be able to read the values off the screen when doing a dummy run.
edwardproj
Edwardproj
Hi Peter,
The program turns a taper and at the end is an arc, when doing the taper it keeps to the feed per rev, then rapids through the G03 and then back to a normal feed on the G1 line afterwards. I switched off arcs in my post-processor to use only linear movements, this works as it should, although not ideal. I have used the Masso post-processor that is built into fusion 360. I have been running the machine for a month now, done lots of turning and threading, but this is the first program I have used CAM and arcs in the program.
t-mr
t.mr
Hi Peter,
I have same problem when using feed per revolution mode on lathe.
Machine moves rapidly on arcs and skips feed rate.
I have tested several g-codes but had same problem on G95 mode.
Now i have to use G94 (feed per minute) to run g-codes correctly.
Regards.
Mohammad Reza Tavakkol.
Thanks @edwardproj and @t-mr
  • Mohammad, can you tell me if you have a G2 or a G3 like Edward.
  • Also what version software you are running.
  • Is this something new or has it been an issue with multiple software versions?
I will investigate this further.
I will run Edwards Gcode file and see how it behaves for me.
t-mr
t.mr
Quote from CNCnutz on May 7, 2021, 7:27 pm
Thanks Peter
Both G2 and G3 work as same.
I'm currently running V4.01 lathe.
Older versions had this problem.
Thanks Mohammad,
I just tested it and can see what you guys mean.
I will get a ticket written up for this to be investigated further.
@edwardproj
Hi Edward,
I just wanted check if you had received the Support desk Ticket update I sent you a couple of weeks ago.
We located the G95 issue rapid on arcs issue and I offered you a pre release software version to try.
You did not get a reply which seems strange.
I have resent the support ticket reply just in case the original email went into your spam folder and is now gone.
If you do not want to try the pre release version then no problem.
If you cannot find the support email please check your spam folder or reply to me here with your MASSO serial number and I will arrange the software for you.
rsacnc
rsacnc
has this new version been released? , I am having a few issues with the lathe version, most importantly the machine not stopping completely once the EMERGENCY button has been pressed while running a program.
Hi rsacnc,
The current Lathe version is 4.01. The version I mention is is a pre release version for the G95 bug mentioned in this topic.
The Estop issue you mention sounds like you are not using an EStop relay on your setup.
To bring your machine to an immediate stop when the Estop is pressed you need to wire a disable for your drives, spindle and anything else you wish to bring to an immediate halt through the Estop relay.
https://docs.masso.com.au/wiring-an...n/e-stop#wiring-e-stop-output-signal-to-relay
