Differance between pendants
angelars
AngelArs
What is the differance between using the MPG pendant, and the playstation 2 controller. They seem very similar to me.
Is it just personal preference on which one to use, or does one have a big advantage over the other?
steelcogs
steelcogs
I haven't used the PS2 controller, so I can't speak 100% for it, but according to the documentation it seems to work for basic axis movement operations and zeroing.
The MPG you can move each axis with precision up to .0005" with the dial. It's pretty nice to have for using an edge finder/probe and it's similar to jogging you would get on an industrial machine. To my knowledge you can't zero any axes from it, however.
Ross
Ross
Just new to cnc myself and still building my plasma table and learning as I go.
As you might know from my post I am trying to fix my mpg, I think it was a power spike that caused the mishap. :(
But it gives great flexibility and precise movement like steelcogs mentioned.
At the moment I am using a Zoweetek Ultra slim wireless keyboard, Model: ZW-51012-1 and I find it good cause you can do all your keyboard commands and you are not tethered to the Masso, Pretty handy with a 3.1 meter long table. "Just something to think about"
But all said when I get the pendent going again I am thinking of a longer lead and will make me more than happy.
Only other thing, if you go for a pendent get one with an E-stop.
angelars
AngelArs
Quote from Ross on September 29, 2018, 1:34 pm
Ross, just to confirm, you are using a wireless keyboard with your Masso?
I ask because I was told that you cannot use a wireless keyboard with the Masso...
I'm using a Logitech MK270 wireless keyboard & mouse combo plugged into a BELKIN 4 port USB hub which is connected to the keyboard input on the MASSO. The setup works beautifully.
For the Bicton Men's Shed.
Ross
Ross
Yes it is wireless and it has a touch pad on the right hand end, I gave the model number cause there are 2 sizes mine is the large size Model: ZW-51012-1 just like a 15" laptop.
Just do a search on the internet to find it,
Masso Keyboard shortcuts.
Good luck, From Ross. :)
