DTHC Disconnecting and Low Voltage Readings.
Bajaracer86
New member
Masso G3 Touch
Masso DTHC Disconnecting (low voltage readings)
Hypertherm 45XP with genuine consumables
Rotary set to 0 for 50:1
Has anybody had this issue, struggling to get it corrected.
I Have been using the DTHC for the last year without issue, The machine was disconnected for a few months but yesterday the machine was cutting fine and reading voltage correctly, I came back a few hours later after the machine was idle to the F2 screen showing DTHC disconnected. Tightened all connections and checked ohms on each wire and pin from the plasma source to the controller. Checked input 9 and jumped it straight to the Masso +red, (its' generally wired to separate power source) it switched low to high on contact. Checked input voltage at the DTHC 24vdc. Tested the arc voltage with a AA battery which measured 1.6v, rotary set to 0 for 50:1 green light flashes but shows 0.0 volts on the F2 screen. When connected and the plasma is triggered it is registering 2.91v at the arc+ on the DTHC which would be 145v for display but is displaying around 60v on the F2 screen, previously it was displaying around 135v with standard consumables cutting 1/4" steel which is close to Hypertherm book settings and worked well, consumables are genuine Hypertherm. I ordered another DTHC module but would like to figure this out.
Send an e-mail to support @ masso dot com dot au with the above details. I don't have a plasma system so I am unable to provide assistance in troubleshooting this device.
Based on my understanding of electronics and control systems it sounds like the rotary switch is simply providing a multiplier for the main controller to use for its calculations and display. Potentially the rotary switch is reporting the wrong multiplier to the main controller. Could you move the rotary switch through all its positions (exercise the contacts) and then retest with the AA battery. Perhaps report the voltage you see on the MASSO controller for each of the 4 rotary switch positions when testing with an AA battery (the MASSO controller will show 0V for any scaled voltage <30V). If the rotary switch is faulty the reported voltage will not be in the expected ratio for the same input voltage (16 : 20 : 30 : 50).
The other potential fault is an input resistor value has drifted significantly higher, thus giving a lower reading.
If you are still seeing 0V when testing with a single AA battery, try using a lithium coin battery (3V) or two AA batteries in series. This should get the multiplied voltage above 30V to get a reading to assist in determining the root cause.
Bajaracer86
New member
Thank you, all good ideas, I will try them and send an email to Masso. I'll reply with the findings.
Bajaracer86
New member
Tested with a 3v lithium coin battery with an actual voltage of 3.32. Exercised rotary switch at each position, measured, then returned to position 0.
Position - Display Reading
0 - 64.8
1 - 36.9
2 - 0
3 - 75
0 - 64.8
Something is very wrong, either with your DTHC module or the on-line MASSO documentation.
That is giving a ratio of 20-11-0-23 instead of 50-30-20-16.
It looks like the rotary switch is used as a multiplier selector instead of a voltage divider tap selector.
Bajaracer86
New member
After contacting MASSO they recommended I bypass the wiring and retest, as well as one other test that I had not performed. All test yielded the same results. Eventually the DTHC quit sending any output signal from the arc+ and arc- with a verified 3v at the input. Right before failing completely, it was sending random crazy voltage readings to the controller, 300, 500, 1500, 400 and so forth. My new DTHC showed up, the rotary switch was testing at the correct multipliers in all positions. Connected into the original wiring it is working perfectly now and displaying the correct voltages at the display. Hopefully the new one last more than a year.
Zombieengineer, thank you for all the help, as well Peter from MASSO.
