Elongated files
cnc-maker
CNC Maker
Hi guys, I am using aspire 8.5. Outputting files to masso using ATC arcs mm.
If I draw a circle in Aspire, it shows on the Masso screen as a oval, but it cuts normally as per the Aspire file
sure to b something basic, any ideas.???
cnc-maker
CNC Maker
Files as drawn in Aspire and how it looks in Masso
I guess its a screen setting somewhere
Hi @cnc-maker
The reason the circle looks like an oval is that you are using a wide screen monitor 16 x 9 to display Standard Definition screen 3 x 4.
Set your monitor to the correct aspect ration and the picture will look correct.
If your circles cut as ovals then your axis are not calibrated or you have backlash.
cnc-maker
CNC Maker
thanks Peter, yeah its just an aspect ratio thing as i suspected. I need to b more observant, I noticed in passing that u have a wide screen on your back wall, so i thought it would be fine. Sadly I did not notice the black bars on the side now that I just went back and had a good look at one of your videos.... I see the black side bars are indeed present
Is there any way I can get masso to display on a wide screen without losing 20% on each side to black bars. I remember Mach having a plugin or similar for wide screens. It would be nice to be able to utilize the wide screen to its full potential
