EMERSON COMMANDER SK VFD NEED HELP.
dap-1750
DAP 1750
ANY HELP WOULD BE NICE.
HAVE WATCHED A VIDEO WITH THIS VFD SETTING UP MACH 3 AND THE BASIC SET UP OF THIS UNIT . I HAVE SET UP AND OPERATED BY THE KEY PAD. I HAVE TO CHANGE PARAMETER 5 TO AI.AV AND HAVE SET PARAMETER 16 TO VOLT.
T1 OV TO MASSO -COM.
T2 0-10 TO MASSO PIN 1
B5 RUN FORWARD TO MASSO PIN 5 OR 4
B6 RUN REVERSE TO MASSO PIN 7 OR 6
THE DRIVE NEEDS B2 JUMPED TO B4 TO ENABLE DIVE 24 VOLTS
POSITIVE LOGIC ONLY B4 THROUGH B7
  • Commander_SK_A_to_D_GSG_3.pdf
the connections look good, if the VFD common signal is +24v then connect MASSO spindle pin: 5 and 7 to +24v
