Be aware that there are similar looking tool setters with 4 wires only and consist of mechanical switches.
Please check your user manual as this product has 6 wires and has active height sensing.
This tool setter comes in either NPN or PNP output format.
Depending on which one you have it will determine how it should be connected.
NPN Tool Setter
PNP Tool Setter
For this tool setter the pull down resistor is not needed
The documentation indicates that there is a Green and Blue wire for an overtravel output on the tool setter.
This appears to be a NO contact but please check your tool setter to confirm
NPN Tool Setter
PNP Tool Setter
