The Estop button on the MPG pendant is designed to either work independently or with other estop buttons on the machine. The user will need to wire the two pin estop connector on the MASSO to make the estop buttons work. If you are only using the estop button on the MPG pendant then wire the positive (+) of the power supply of MASSO to pin 1 (green connector) on the Estop connector.
Wiring example with one E-Stop button on the machine:
Wiring example with E-Stop button on MPG Pendant and machine:
