Ethercat / or IO Bus support please
gomond
gomond
Hopefully you could add a bus interface to the masso so that you could start adding interface options like ether cat ,can bus, and even better pendant support like some of the usb pendants.
Maybe even a programming API for Add On's.
Thanks.
Greg
tayloredtech
TayloredTech
Quote from gomond on September 29, 2021, 10:20 am
Thanks.
Greg
Modbus support or simple RS485 would be great. Can bus would be the best thing for CNC, funny enough snapmaker CNC/laser/ 3D printers actually use it.
If it does happen, check out UIRobot steppers, I have the RS232 version and they are AMAZING, they make them with CAN aswell, If I found a controller that supported CAN I would 100% use these.
MKrupp
New member
Being able to plug into a wired network would be great, Along with a full blown interface you can access from any computer on the local network, like the Buildbotics system does.
