I now have the machine up and running, It is configured as follows. Fanuc Motors, I made some adaptors and use US Digital encoders on X and Y at 2000 PPR . Z is a Fanuc Motor as well with a AMT 102 encoder. running at 1000PPR.
These are all fed by DG4S drivers, The drivers are supplied with individual power supplies which use the original 3 phase transformers and custom built rectifier circuits following the recommendations for filter caps. X and Z are 56 volt motors.
The Y axis motor is a 108 volt motor and required a larger capacitor and also a break circuit to eliminate the back EMF pulses.
The drives are directly interfaced to the Masso with a board I built which allows for the alarm codes to be broken out for the axis alarm functions of the Masso to work.
I used the Masso output relay block to drive the spindle, and coolant functions. This is accomplished by just driving the existing motor contactors with Solid State Relays and works great.
I have two small power supplies one 12 volt and one 24 volt feeding all the Masso control circuits.
The system is working well at this point and I have done some parts that came out well though it was by use of the position buttons in more or less a manual mode to move the servos. I am in the process of learning a Bobcad program for automatic ops the near future and it is getting exciting for sure.
One question I have is in regards to system resolution. The motors are the same and the screws and the encoder resolution is the same as With the old Fanuc system, On that system I was seeing resolution steps down to .0001. That means I know the machine and motors are capable of doing it. This control system does not seem to get movement below .0005 (Thou) on the DRO. and jumps in that increment. Is there a setting I missed somewhere or anything I can do to change that to replicate the old system accuracy?
Regards, Steve
Regards, Steve
