Feature Request: "A HALT Input Pin Function"
(Edit: Sorry, this should have be posted in Feature Requests, now trying to move it)
(Moved it for you. Arie. MASSO Support)
I have several Devices on my Masso CNC machine that I would like to know that they are NOT in trouble and NOT ajar. For example, I would like the system to stay-in or change-to a HALT mode, if: the Dust Brush has has be knocked ajar, or the Side Spindle Probe is not in place (or other future devices statuses). Each of these devices have break-away mounts to avoid major damage "when things go wrong". Device internal switches provide electrical status of each.
So far, I have not found anything that suggest this is possible with Masso, and therefore this Feature Request.
Am I missing something, does this capability already exist, or does anyone have a suggestion?
I have thought of one kludge method to DIY implement a HALT status button/circuit: That is to: run my device status circuit voltage to a "multi-vibrator module" which would feed fast ON-OFF pulses into the "Cycle Stop Button Input" line. These pulses would only exist while a problem is detected, or when I turn-on or press a table side button. I will be attempting to implement this Kludge in the next few days.
Also See: https://www.masso.com.au/forums/topic/trouble-trying-to-undefine-and-input-pin/
Note: I have mixed feelings about the current implementation of "Cycle Stop", which currently does not stop the Spindle (I understand both sides of the argument), For our use, I will deal with that issue later.
-Eldonb
-Eldonb
