feed and speed changes
rroie
rroie
Can not get Masso to increase feed and speed. Used to do it. I have v3.43. Work around to increase feed and speed?
Thank You
Roie
Hi rroie
F11 & F12 are the feed and speed override keys using the + & - or the MPG to increase or decrease as needed.
Masso has never been able to increase the feedrate over 100% so I'm not sure what you are referring to. Can you clarify?
rroie
rroie
Yes, I have those keys marked with tape and the appropriate function. Has saved me a few times when feed was way too fast. I am in the middle of this project now. When I can get through it, today I hope,
I will send some code through Masso just to test speed and feed changes.
The CNC was going too slow yesterday and I could not speed it up. Took longer than it should have to finish. Then everything quit working.
Thank You
Roie
