Fibre Laser
lilow
Lilow
@breezy
If you watch the spray underneath the cut in the video, you will notice the cut spray goes nearly vertically down around the cut.
This is what is needed, many other factors come into it that can't be found.
Cheers.
lilow
Lilow
Who would have known that the up front code in the G3 for the Plasma (G200) could deliver different situations.
With that up front code seen in 2021, it happens now.
The photo included is straight off the table.
It's been challenging, but worth it.
Cheers.
Very nice....
What pressure are you using for the compressed air? I remember you posting that the recommended pressure was X bar which was more than regular air compressors could achieve.
Does the air pressure have much impact on cut quality?
lilow
Lilow
Very nice....
@zombieengineer
These cuts were done with Oxygen, will go back and try again with compressed air soon.
I found an article of cutting at 80PSI with air, got to follow it up.
Cheers.
lilow
Lilow
Cheers.
I was thinking today, where has Peter (cncnutz) been, appears he is still around, that's good.
Cheers.
lilow
Lilow
Started cutting the internal structure of the bed today.
Had an issue with the G3 on the final cut in the software.
This didn't allow the the cut to be done.
Was able to around it by running the file until the the last cut, then turn Power on, done.
Got results that came out spot on.
There were two plates cut.
Cheers.
IMG_3768[1].JPG\
lilow
Lilow
Now getting into an area of unknown, raising the bar on the KHz, the power source is capable of 20 KHz, let's try and use it.
Everything I have read is that the nozzle could over heat, this does not happen if the beam is in focus.
Cut various plates at different KHz, will study them in the morning.
Cheers.
lilow
Lilow
Left the settings as they were yesterday.
(will check on the 15KHz during the week)
Cut some bigger panels for the waste tray area (it takes more time drawing / programming than cutting).
It's magnificent the way it cuts dross free (no cleanup required), the parts cut just lift up and out.
Cheers.
Lilow is having a party with these cuts. Sparklers - Extra large :oops:
I know plasma cutter does produce something of a spark show of blobs of molten metal, but this is closer to a molten metal spray gun.
lilow
Lilow
@zombieengineer
When the spark show is like it is, the cut outcome will be great.
It is easy to say, I should have had one of these when I was building frame rails / chassis's.
I'm really astounded by the quality of finish this machine delivers.
The G200 coding of the G3 works perfectly.
All the design, building, testing has paid off, even though the learning curve was vast.
Cheers.
I suspect the difference is the spot temperature for a laser is much higher and the liquid metal has a lower viscosity (flows like water rather than thick syrup). Makes it easier for the gas to strip the metal out of cutting zone.
You are probably getting nice shiny cuts using nitrogen as it is basically inert (no oxidation). If you used compressed air I suspect the surface will have a grey finish (light coating of black magnetite).
The only metals that off the top of my head that react with nitrogen at elevated temperatures are Magnesium and Titanium.
lilow
Lilow
@zombieengineer
As I think I mentioned, using Oxygen.
Did you see the split in the spray going in one direction.
I think this is cutting both sides of the cut evenly and straight.
Also on piercing, you can see a single beam before movement.
A lot of things get noticed when evolving areas.
Cheers.
Ozymax
Member
I had some steel cut by our local steel company recently and figured I'd post a photo of the surface finish of the plate, just for reference.
I was pretty happy with the surface finish.
Looks like the finish you're getting. :love:
lilow
Lilow
I also got them to etch some future hole locations. I opted not to cut these holes as they are mainly small in diameter and didn't want to risk any blowout from the piercing destroying the surface.
Thanks, HA250 is oiled & pickled, who polished it ?
Got to ask, did you get it bevel cut on the circular part ?
Cheers.
lilow
Lilow
Right now, feeling relieved that this project wasn't in a vain attempt to do something that some may have thought not possible.
The knowledge gained from the first Plasma build in 2000, the 3D Tig a while later and now this.
The collective situation has allowed me to use the DT115 comparator board that I redeveloped into an accurate control for height, now the development of the Laser control box.
It's been a big win personally.
So thanks to all you guys worldwide for watching, last count it came up at +52K of views.
Thanks all those who had a say along the way.
I have nearly cut all the parts designed for the bed, so will start installing them.
A special thanks to Masso who didn't realize that their G200 code fitted the purpose, I must have seen the usefulness of it straight away.
A photo of some the last big panels to be cut, each one of these took around 4 minutes to cut, with no clean up required ( design time / programming a lot more).
Cheers.
When this is done, maybe look at Fibre Laser Welding in 3D with height control, this Raucus power source used was only meant for welding so knowledgeable people said.
