@zombieengineerIf the "Special" was cut with the laser, then you are effectively showing off the accuracy of the fiber laser. (dotting the "i" is pretty damn impressive)
I doubt you could cut that fine with a plasma cutter.
![IMG_4075[1].JPG IMG_4075[1].JPG](https://forums.masso.com.au/data/attachments/13/13180-c8ebca2405efc4dd6c523779f526ab4b.jpg)
@zombieengineer
Thanks, all in all, it has worked out well.
The Plasma was good, but it couldn't do anything to this accuracy.
Those 5mm plates had no dross on the underneath side, put them straight into the white vinegar bath to de-scale them.
Cheers.
@segoman-designsDoes your steel supplier offer P & O (Pickled & Oiled) Sheets? It gets de-scaled and oiled at the mill, the cost is cheaper than you can do it on site.
| Part Number | Pin Count | Footprint | Typical Rise / Fall Time | Max Operating Temperature |
| SFH615A-2 (Your Current Part) | 4-Pin | DIP-4 | ~3.0 µs / 14 µs | 100°C |
| VO617A-2 | 4-Pin | DIP-4 | ~2.0 µs / 2.0 µs | 110°C |
| SFH617A-2 | 4-Pin | DIP-4 | ~2.0 µs / 2.0 µs | 110°C |
![IMG_4093[1].JPG IMG_4093[1].JPG](https://forums.masso.com.au/data/attachments/13/13200-4f5f696ede391d0032fb6e8867dcdd12.jpg)
To achieve fall times approaching 2 microseconds requires a 75 ohm load resistor on the output (the data sheet quotes RL=75 ohms @ 5V), specifically the larger the on current the quicker the device turns off. The more realistic number is to look at the "saturated turn off time" which is closer to 25 microseconds.The Fastest 4-Pin Upgrades
@zombieengineerTo achieve fall times approaching 2 microseconds requires a 75 ohm load resistor on the output (the data sheet quotes RL=75 ohms @ 5V), specifically the larger the on current the quicker the device turns off. The more realistic number is to look at the "saturated turn off time" which is closer to 25 microseconds.
I prefer to use the photodiode of a 4N25 (6 pin device) and a BC547/BC557 (depending on the required output type) when I feel the need for speed. The xx615 & xx617 optocouplers are good for about 20 kHz, while the 4N25 with transistor can consistently reach 190 kHz switching rates. To put that into perspective, the 4N25 in photodiode mode can cycle twice as fast as the MASSO controller can generate motor steps (109 kHz from memory). For reference using the transistor output of a 4N25 is no better than the xx615/xx617.
Experimental project to implement Rigid Tapping
Just finished a long term project and think it is time to deal with the thorny issue of rigid tapping. At this point of time MASSO has yet to implement rigid tapping as other stuff has been deemed higher priority (including the release of the MASSO touch - it has been on their "Todo list" that...forums.masso.com.au
![IMG_4103[1].JPG IMG_4103[1].JPG](https://forums.masso.com.au/data/attachments/13/13204-99fe0432dd3429e079ce6f7b6d74edbc.jpg)
